PLM 360: I get this System Error message "you have made an invalid request, please use your browser's back button and try again" when I try to export BOM to excel, but only in nested view, not in flat view. Used to work fine, I did make some changes to the item identifier set-up, added fields, moved some around. is there a way to put them back to defaults?
Solved by droth. Go to Solution.
This issue has bee reported and being working on currently. I'll circle back and let you guys know when's it's been addressed.
Michelle
Just following up to let you know this was fixed.
Michelle
