I am new to PLM360 and would like to build my scripts in libraries and classes etc..
I would like to know if there is a published syntax (java) supported in PLM360?
Thank you,
Solved by broepke. Go to Solution.
Take a look at the help file. There is a full set of examples and information about functions and objects, etc... as a good starting point the language is based on JavaScript.
http://help.autodesk.com/view/PLM/ENU/?guid=GUID-1EFE1FAC-1CFF-4F2E-987F-9801DF590E57
Also - a great way to get going is to run a script through the advanced debugger we just released. If you've done any coding you should feel right at home with this.
http://help.autodesk.com/view/PLM/ENU/?guid=GUID-764824AA-A429-4995-ACC0-64EEFB033507
One more thing - Scripting is for server side control of items and workflows. Typical use case is to execute logic when workflows are performed in the form of conditions, validations and actions.
If you want pure API access to the data in a CRUD fasion you can use the REST API. With REST you can use just about any Programming Language:
See Here: http://help.autodesk.com/view/PLM/ENU/?guid=GUID-3825A309-3130-4F2D-82F1-68D189D03B02
