In the Attachments tab I can add a Description when uploading a new file. That file can then be checked out and when checked back in a new Description can be entered.
To view previous versions of the file I then click on the History button. However, the only details available are Version #, File Name, Date, and User. Is it possible to see the Description associated with a previous version of a file? I'd like to use the Description field as more of a comments field to give some context to that particular version of the file.
Thanks.
Joe Hendrickson
Solved by nguyentru. Go to Solution.
Hi j.hendrickson,
Currently the Attachment History will only display the Version #, File Name, Date and User.
You have a good idea and I think you need to submit this to the Idea Station.
Thank you,
Trung
