Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Scripting Error "item" is undefined
2 REPLIES 2
MrSJM88
508 Views, 2 Replies
I am having some challenges with a script that will create milesstones, triggered by the creation of a record.
See below for the script created:
if(item.milestones.length <=0){
var mStoneDef = [];
mStoneDef['Quote Complete'] = 25;
mStoneDef['Customer Approval'] = 50;
mStoneDef['Implemented'] = 100;
createMileStones(mStoneDef,7,'ENTER',2);
var someDate = new Date();
var numberOfDaysToAdd = 7;
someDate.setDate(someDate.getDate() + numberOfDaysToAdd);
item.TARGET_QUOTE_DATE=someDate
When I test the script I recieve an "item" is undefined error. I did not set any values in the testing parameters.
Could someone help me out when the get the chance?
Stephen
2 REPLIES 2
jpiggee
in reply to: MrSJM88
Hi Steve,
I know we worked on this offline, but I figure it would be best to swing back to this and also provided the answer hear as well.
The script that was being used is correct
  1. The usage of the transition names is correct
  2. The structure of the script is also correct
  3. The creation and placement of the date is also correct.
However, what we found was that in our haste to fix and use this script we over looked the library that is required by the function of “createMileStones”.
Once this was added to the script in the section “Imports”, we were able to get this running correctly.
Nice Job Steve!
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
michelle.stone
in reply to: jpiggee
Thanks for circling back and sharing the solution for all!
Michelle
Michelle Stone
Technical Marketing, PDM & PLM
Autodesk, Inc.
