Hi I just saw that there was a update for Scripting Access to Linked Items. I wanted to know how to exactly use it. The Wikihelp section only tells you that theres a new object array: itemWorkflowItems, it doesnt really tell you how to use it with an example script.
Can someone provide an example script using this feature?
I was able to get it working over the weekend. The following is a bit of the code that I used;
var linked_item = loadItem(item.workflowItems[1].id);
linked_item.ORIENTATION = 'Vertical';
Hope this helps.
David.
From my testing you can use the new functionality the following way;
item.workflowItems.length [Number of linked items]
item.workflowItems [Returns entire array]
item.workflowItems[i].id [Returns the id of the row number i in the array]
item.workflowItems[i].descriptor
Hope this helps,
David.
