Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Scripting Access to Linked Items
2 REPLIES 2
Asingh5
356 Views, 2 Replies
Hi I just saw that there was a update for Scripting Access to Linked Items. I wanted to know how to exactly use it. The Wikihelp section only tells you that theres a new object array: itemWorkflowItems, it doesnt really tell you how to use it with an example script.
Can someone provide an example script using this feature?
2 REPLIES 2
dkeeley
in reply to: Asingh5
I was able to get it working over the weekend. The following is a bit of the code that I used;
var linked_item = loadItem(item.workflowItems[1].id);
linked_item.ORIENTATION = 'Vertical';
Hope this helps.
David.
dkeeley
in reply to: dkeeley
From my testing you can use the new functionality the following way;
item.workflowItems.length                 [Number of linked items]
item.workflowItems                            [Returns entire array]
item.workflowItems[i].id                      [Returns the id of the row number i in the array]
item.workflowItems[i].descriptor
Hope this helps,
David.
