Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Scripting access to BOM Supplier/Part Number
2 REPLIES 2
351 Views, 2 Replies
Is it possible to directly access the Supplier/Part Number field in a BOM via scripting? The only way I have found to access this information is to compare the Quote from the BOM item using item.boms[index].quote to the sourcing quote of the item using item.boms[index].item.sourcing[index].quote[index]. The supplier can then be pulled from the second Quote. However, this method includes many loops and I am having script timeout issues for longer BOMs. Can someone provide some insight on a better/more efficient way to do this?
Thanks!
Matt
Tags (2)
2 REPLIES 2
gasevsm
Hi Matt,
Presently, traversing over the suppliers' quotes is the only way to get to supplier number for a given bom component. Absolutely, there is value in providing direct scripting access to supplier for the in-use quote of a bom component. This would eliminate looping over all quotes of all suppliers for each bom component to find a match. I will add this on my roadmap for future release.
Tentatively, the form would likely be in the lines of:
    • item.boms[i].quote.sourcing.supplierPartNumber;  // or get to the supplier's part number directly
    • var supplier = item.boms[i].quote.sourcing; // (read-only) access sourcing object to retrieve supplier or any other field or its list of quotes
Thanks and best regards,
Martin Gasevski | Product Manager | Autodesk PLM 360
Martin Gasevski | Fusion 360 Team Product Manager
in reply to: gasevsm
Hi Martin,
Thanks for the update. Direct access to this information would be very helpful in simplifying scripts and cutting down on the number of loops needed.
Matt
