PLM 360 General Discussion
dkeeley
Message 1 of 5 (175 Views)
Script Time Limit Exception
175 Views, 4 Replies
10-11-2012 04:00 PM
I have developed a script to update the derived fields on some records I have imported (there is currently a bug where derived fields do not resolve during import - they only reolve when the item is edited). The problem is that I have over 5000 import records to modify (dmsID 50575 to 55716).
The script below works (I use the workspace 'create' behaviour to call it). However when I try to run it for more then 200 or so records I get a 'ScriptTimeLimitException' error (see attached). Please advise.
The scirpt is:
//This script resolves derived fields. Required because serived fields do not resolve during import.
record = 50575;
do{
    var newItem = loadItem(record);
    if (newItem.CONTRACT_NUMBER4 != null){
        var linked_item = newItem.CONTRACT_NUMBER4;
        if (linked_item.CUSTOMER != null){
            newItem.CUSTOMER4 = linked_item.CUSTOMER;
        if (linked_item.DETAILS != null){
            newItem.DESCRIPTION2 = linked_item.DETAILS;
    record++;
}while(record <55717);
Board Manager
broepke
Message 2 of 5 (154 Views)
Re: Script Time Limit Exception
10-12-2012 06:45 AM in reply to: dkeeley
Scott,
Clever :smileyhappy:  That's a system limitation so we don't have "run away" scripts.  Think of cases where stuff is just so intensive that it actually affects the performance of your site, etc...  It's set to 500 ms.
So - What you can do is break it down in chuncks.  Try processing 1/2 of them first.  Then edit the script and do the other 1/2.  That doesn't fly do 1/3 or whatever.
(or chunks of 1000? I have no clue how many it can do... It will take some experimenting.
Brian Roepke
Director of PLM & PDM
dkeeley
Message 3 of 5 (148 Views)
10-12-2012 08:39 AM in reply to: broepke
Hi Scott,
I can only seem to get it to run for about 200 records at a time. Is there nay way to make the code more efficient as you see it? (i'm not a software person BTW) ;-)
David.
dkeeley
Message 4 of 5 (147 Views)
10-12-2012 08:41 AM in reply to: dkeeley
Sorry. Brian - not Scott.
Employee
jared.sund
Message 5 of 5 (138 Views)
10-12-2012 09:20 AM in reply to: dkeeley
I don't see any obvious performance issues with your script, however you may be able to gain some performance using a multi-pick list and not the loadItem function.  This approach might take a couple of temp workspaces to get through the process, but could increase your chunk size.
Jared Sund
Sr. Product Line Manager, Product Lifecycle Management
