Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Script - Integer value from picklist
4 REPLIES 4
Tony.Gonzalez
428 Views, 4 Replies
Script - Looking for a script to take an integer value (1-5) from a picklist radio button selection. The idea is to have the user creating the WS record select from a list of 5 options and then have the WS record retain the selection integer that corresponds with the selection. Currently in PLM 360, the picklist function does not return a predictable integer value, known issue, no planned fix.
4 REPLIES 4
gasevsm
in reply to: Tony.Gonzalez
Correct. If you change the picklist definition and inject selections as opposed to append, its index changes with it.
Martin Gasevski
Martin Gasevski | Fusion 360 Team Product Manager
gasevsm
Correct.  If change the picklist definition and inject selection options, its index changes with it.
Tony.Gonzalez
in reply to: gasevsm
Thanks, however, I am not clear what you mean by injection options. Currently the picklist options I have are setup as follows, example:
1 - No Goals or Vision
2 - Assumed Goals
3 - Agreed Goals and Assumed Vision
4 - Confirmed Goals and Vision
5 - Measured Success Towards Goals
I need the radio button selection to return the corresponding integer value. I was told by support the only way to insure the correct integer value was scripting. Any advice?
broepke
I have a great tip for this.
If you want to make sure your numbers match the assigned "background" integer you CAN make this happen.  Normally when you create a new pick list you add all the values to the new list and hit "Save" - here it basically adds them to the back end database in a random order.
HOWEVER -
if you add these values one at a time - SAVING the pick list after each value the integers will get assigned in the order you want.
  1. Create a new pick list
  2. Type in the first value and only this value - such as "1 - No Goals or Vision"
  3. Save and close the pick list
  4. Open the pick list again for Edit
  5. Add the next value "2 - Assumed Goals"
  6. Save and close
  7. Repeat
Once you do this you can validate the value but it will assign the integers (pick list index) in the right order:
Brian Roepke
Director, Analytics & Insights
