Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Run Script on Grid tab edit
1 REPLY 1
jdow
533 Views, 1 Reply
Is it possible to react to editing the information in the Grid tab and then execute a script, like you can using the 'Script to run when item details are modified'?  I.E. I want a script to run after a user modifies the data in the grid tab and update an item field on the items details tab.
If yes, how do you approach this?
Thank you,
John
JD
1 REPLY 1
gasevsm
in reply to: jdow
Hi John,
Presently, scripts can automatically be triggered only when saving a new item on create/clone or upon edit of itemDetails tab. Manual eventing is possible via onDemand behavior. Other tabs don't support eventing behavior at the moment.
Martin Gasevski | Fusion 360 Team Product Manager
