Is it possible to react to editing the information in the Grid tab and then execute a script, like you can using the 'Script to run when item details are modified'? I.E. I want a script to run after a user modifies the data in the grid tab and update an item field on the items details tab.
If yes, how do you approach this?
Thank you,
John
Solved by gasevsm. Go to Solution.
