Is there a way I can pin a revision to the upcoming revision?
The need occurs when I have a Change Order where I am both releasing items and a BOM referencing those items.
BOM unreleased -> A
ITEM1 unrelease -> A
ITEM2 unrelease -> A
From what I can see then I have to release all items hierachical from the lowest level and up and then apply pinning as I go.
Is there a way to get around this?
Solved by sten. Go to Solution.
