Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
REST API v2 - Upload problem - multiple revisions
2 REPLIES 2
ac
290 Views, 2 Replies
I have a problem uploading multiple revisions of the same file (i.e. attaching a file to a workspace/item). A new file works fine, the same does the second revision of the file. However, upload of the third revision always seem to fail.
I start uploading a new file with the following API call and JSON FileUploadRequest:
POST https://contex.autodeskplm360.net/api/v2/workspaces/29/items/2897/files
{"fileName":"Demo1.jpg","title":"Demo1","description":"Uploaded from Contex"}
This works fine and I get the usual JSON file collection in return.
Then I do a checkout and a second upload of the same file using the same JSON FileUploadRequest:
POST https://contex.autodeskplm360.net/api/v2/workspaces/29/items/2897/files/99/checkout
POST https://contex.autodeskplm360.net/api/v2/workspaces/29/items/2897/files/99/checkin
This also works fine and I get an updated JSON file object in return.
Finally I repeat the checkout/checkin sequence for the third revison of the file now using the file ID of the second revision:
POST https://contex.autodeskplm360.net/api/v2/workspaces/29/items/2897/files/100/checkout
POST
https://contex.autodeskplm360.net/api/v2/workspaces/29/items/2897/files/100/checkin
The checkout works fine i.e. I get status CHECKEDOUT in return (the file also shows up checked out on the PLM web page).
However, the upload/checkin fails with the following strange JSON response leaving the file checked out:
{"errorCode":"UNKNOWN","message":"Unknown error.","params":null,"url":null,"errorClass":"APIError"}
I have also tried using the original file id (99 in this example) for the second revision chekcout, but then the checkout fails with errorcode FILE_CHECKOUT_FAILED as I would expect.
Am I doing something wrong or is there an API problem with multiple file revisions?
2 REPLIES 2
gasevsm
in reply to: ac
Please specify the version number in your payload with every call to create a new version. Let me know how this works,
Martin Gasevski | Fusion 360 Team Product Manager
ac
in reply to: gasevsm
When you say payload, do you mean the JSON object sent with the checkin command?
I have tried the following JSON without luck:
{"fileName":"PageDropDemo7.jpg","title":"PageDropDemo7","description":"Uploaded from PageDrop","version":3}
In return I get:
{"errorCode":"GEN_EMPTY_INPUT","message":"Empty input.","params":null,"url":null,"errorClass":"APIError"}
