Is there a way to generate an Outstanding Work report ?
I would like to generate a report including either all items in "My Outstanding Work" or all items "My outstanding workflow for [WS]".
And even better, send such report(s) by email.
Hi sten,
TYhere is no direct way. Reason being is oustanding work is dynamically calculated list based on whether user has specific WF permissions for the state its presently in, is qualified by the outgoing condition script logic (if any) and whether transition/state drive whether item should show up in user's outsanding work list. The answer of whether its possible to generate such report depends on ability to key off the same flags/conditions in reports that are used in calculating myoutsandingwork. eg. if your criteria that determine whether item shows in my outsanding work list is if user is owner, you can create a report where owner is X or you for that workspace.
Hope you get the idea,
Ok,
That is too bad. Since PLM is already able to do it, I was hoping just to get access it that way.
It does not have to be up updated up to the minute.
I understand how I could re-create all the workflow conditions is a report, but that would quickly become difficult to maintain (synchronized).
Sten
