I'm trying to create a report that shows the total number of completed change orders for this current month with the total items that were changed (what was added on the Managed tab). I don't see anything in the report groupings to relate back to the Managed tab. What am I missing?
I have selected in the Grouping: Change Order Number, Last Action, Facility
Display Columns show: Change Order Number, Last Action, Facility
Filter shows: Current State contains Released & Last Action Date for this Month
I'm sorting by Change Order Number
No Chart.
How do I now add in the number of Managed Items related to the Change Order?
Solved by broepke. Go to Solution.
I think I have what you're looking for. However I didn't add as many items to count on the chart so that might add to the complexity.
First off I set the grouping so I can get the dates grouped by month as well as the "Item" (wich was the field called "item" from the managed item tab...)
Then... you can see my fields how I have them set - including which ones are set to "count" so i can get the right totals.
Finally... the results. Is this close?
This is a little better view of what fields are added and which one's are set to "count"
Yes that was it. I didn't realize the link item went to the Managed Items. Thanks so much for your help!
