Is there a way to print the rollup in the project management, or even export what is seen on the screen to a power point?
To print the chart, you can create an "Advanced Print View". Insert that into your pring view and give it a try. Here is one I just did of my simple Gantt. This was done by doing nothing more than inserting the "tab" artifact into the print view, no other changes.
from here you can print the output.
Brian,
When creating an advanced print view to print a schedule for a project, is it possible to show the sub-projects and sub-items in the print?
Here is an example. We need all of the following line items to show up in the print view...
We want "Project 1.A" and "Testing" to appear. But when I create an advanced print view and use it, the print preview shows up like this....
As you can see, "Project 1.A" and "Testing" do not appear.
Any thoughts on how to get the sub-level line items to appear?
Eric
