Hi All,
Is there a way I can add link items to the project management tab pivoting off a selection in another workspace?
I Have three workspaces: "Workshop", "Suggestion Board", "Part Specific".
In the suggestion board I have a picklist where you can select the workshop that suggestion is related to. What I would like to happen is when you select that workshop in the suggestion workspace it would also add that suggestion to the project management tab in the "Workshop" workspace via a script.
Is this possible to do with a script?
Stephen
Solved by nguyentru. Go to Solution.
Hi Stephen,
Currently our system will allow you to connect to the Project Management Tab in another workspace.
Workspace A = Project Management Tab; Workspace B = has a linking picklist to Workspace A
if(iem.PROJECT_LINK !== null)
item.PROJECT_LINK.project.addTask(item, new Date(), new Date(), 10)
