I am having some problems with a "Linking Pick List (With search filter)".
I can't clear the field if I previously have selected something.
If I click the red X I get:
And the picklist is cleared, except a NBSP is inserted.
I can't figure out how to delete the
Solved by JohnCHill. Go to Solution.
Is the picklist value assigned to an existing field?
Can you attach a screenshot of the configuration of the picklist field in question so I can understand the issue better?
Sten,
I can duplicate your results and will escalate this to the PLM 360 Development Team.
Thank you for bringing this to our attention.
Hi John,
We are also getting this issue on our tenant. Is there a workaround or fix available?
Ross
