Is it possible to pin a revision of an item in a BOM via a script? I would like to be able to pin all items in a BOM when the workflow reaches a certain point. As far as I can find, this is a manual process that must be done.
You are correct Matt. It is not possible at this time to set Revision Pinning on a BOM via scripting. There is a way, however, to set it via Imports if you want to do that. You can export a BOM that has some pinned items to excel to see what format will be accepted on the way in. Note that you cannot use Parent-Child style import to set Revision Pinning, but any of the other BOM import methods will work.
