hello,
even if parent-child is not the preferred solution, it is unfortunatly the easiest one for us due to:
1. amount of data (need to have (too) many splitted files
2. multisource of information
then, in one file we can have
PARENT CHILD
A000001 A000002
and in antoher one:
PARENT CHILD
A000001 A000003
at the end the BOM Shall be as:
A000001
|-------A000002
|-------A000003
but we discovered that if you import file 1 and then file 2 (knowing that the option "For existing BOM relationships" is set to "Update the workspace") we have the following result:
A000001
|-------A000003
if know this information is on the same file, it seems to work... it is strange behavior... on a small set of data we have tried hierarchy method, it works fine but it would be too much effort to transform our data set ..... (any 'magical' solution on that may be?)
best regards
