Hi all,
Is it possible to set a workspace so that only the owner of an item is able to change ownership? I still want all users with permission to view the workspace to see the item. The workspace I want this function in is a basic workspace with workflow, but I suspect this is an issue for all types of workspaces.
The only settings I've found is "Change ownership" in permissions, but this permitts changing owner on all or none of the items.
Best regards
Johan Kenneberg
Solved by dvirh. Go to Solution.
Hi Johan,
There are several ways that the Change Ownership functionality is used. Here are a few examples:
What is common to all of these use cases is that the person who is performing the action is not necessarily, and sometimes necessarily is not, the person who is the owner of the item. What is also true is that no matter who is performing the action, the action is logged in the change log providing full traceability to what has happend.
The point I'm trying to make is that we don't see the permission to change owner as a way to control security, but rather as a way to enable a streamlined workflow in various use cases.
