How can I create a number field in Item Details that allows for 2 decimal places? Integer data type does not allow for decimals, and none of the other options seem to make sense for this. I've attached a screen shot showing the data type options I have. Thanks!
Great. That seems to work, but I'm having trouble changing a computed field from integer to float. Do you know what might be causing the error message in the attached screen shot?
Try deleting current field, and create a new one as float type using same system name re-adding the computed field.
HTH,
