PLM 360 General Discussion
389 Kudos
Post 1 of 8
Nice scripting error for you guys
157 Views, 7 Replies
10-04-2012 12:27 PM
On creating an Item I got the following scriting error:
Since it made no sense to me & didn't appear to point to anything wrong with my script, i decided to try & create the item again. It worked... But its the longest 'scripting' error I've seen so far so I thought I'd share my landmark moment. :smileyhappy:
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
Product Support
48 Kudos
Post 2 of 8
Re: Nice scripting error for you guys
10-04-2012 12:31 PM in reply to: scottmoyse
Hi Scott,
Mind posting the script(s) you were using JAVA and computed fields.
Joe Piggee
Support Specialist
Product Support
389 Kudos
Post 3 of 8
10-04-2012 12:47 PM in reply to: piggeej
item.NUMBER = item.PROJECT.CONTRACT_NUMBER + "-" + item.DECK + "-" + item.AREA;
if (item.AREA <= 9)
{item.WORK_PACK_NUMBER = item.DECK + "0" + item.AREA;}
else
{item.WORK_PACK_NUMBER = item.DECK + item.AREA;}
//=========== sets the related product's Work Allocations ======================//
setLists();
//=========== sets the current Items Number ======================//
item.NUMBER = item.RELATED.CONTRACT_NUMBER + "-" + item.DECK + "-" + item.AREA;
if (item.AREA <= 9)
else
Cheers
Scott Moyse
389 Kudos
Post 4 of 8
10-04-2012 12:48 PM in reply to: scottmoyse
setlists:
function setLists(){
var desc = item.descriptor.descriptor;
var tempProduct = null;
if(item.RELATED_TEMP === null){
item.RELATED_TEMP = item.RELATED.descriptor.descriptor;
else if (item.RELATED === null && item.RELATED_TEMP !== null){
tempProduct = new parentObject(item.RELATED_TEMP.descriptor.dmsID);
tempProduct.removeItem(desc);
item.RELATED_TEMP = null;
else if(item.RELATED.descriptor.descriptor !== item.RELATED_TEMP.descriptor.descriptor){
//item.RELATED_TEMP.RELATED_WORK_ALLOCATIONS = removeItem(item.RELATED_TEMP.RELATED_WORK_ALLOCATIONS, item.descriptor.descriptor);
}//end if
if(item.RELATED !== null){
var product = new parentObject(item.RELATED.descriptor.dmsID);
product.addItem(desc);
}//end if
function parentObject(dmsID){
this.myObject = loadItem(dmsID);
this.addItem = function(descriptor){
if(this.itemExists(descriptor) === false){
var currentValues = this.returnItems(descriptor);
currentValues.push(descriptor);
this.myObject.RELATED_ITEMS = currentValues;
this.itemExists = function(descriptor){
if(this.myObject.RELATED_ITEMS === null){return false;}
for (var i = 0; i < this.myObject.RELATED_ITEMS.length; i++) {
if(descriptor === this.myObject.RELATED_ITEMS[i].descriptor.descriptor){
return true;
return false;
this.returnItems = function(){
var currentValues = [];
if(this.myObject.RELATED_ITEMS === null){return currentValues;}
currentValues.push(this.myObject.RELATED_ITEMS[i].descriptor.descriptor);
this.removeItem = function(descriptor){
if(descriptor !== this.myObject.RELATED_ITEMS[i].descriptor.descriptor){
Cheers
Scott Moyse
389 Kudos
Post 5 of 8
10-04-2012 12:51 PM in reply to: scottmoyse
There's one computed field in the item details:
BUDGET_HOURS-HOURS_TO_DATE
Cheers
Scott Moyse
Product Support
32 Kudos
Post 6 of 8
10-04-2012 01:14 PM in reply to: scottmoyse
Scott - I just came across pretty much the same error in another tenant.  Will report.
And same as you - retrying worked.
Michelle
Michelle Stone
PLM Product Manager
Product Support
48 Kudos
Post 7 of 8
10-04-2012 01:21 PM in reply to: scottmoyse
Scott,
Looks like an issue with stamping userids to the logging section on item creation, checking with the powers to be right now.
Joe Piggee
Support Specialist
Product Support
389 Kudos
Post 8 of 8
10-04-2012 01:31 PM in reply to: piggeej
sweet :-) glad i reported it then
Cheers
Scott Moyse
