is it possible to modify the date of an existing milestone using scripting? If so can you provide an example?
David.
Solved by michael.pares.old. Go to Solution.
Solved by gasevsm. Go to Solution.
Hi Martin,
Thanks for the quick reply. I'm delighted that this will be coming soon - it is badly needed and will prove very useful
David.
Sure. We do this all the time. Here is a library script that we use to change the milestone date.
//Reset a milestone due date
function resetMilestoneDate(milestone, dueDate) {
milestone.milestoneDate = new Date(dueDate);
return; //null
