Hello Team,
Good day.
I have a workspace there is a field which is linking picklist item with search filter from another workspace.
I am able to filter the item in edit mode and save it.
However in an action script, when I try to access the linked item I always get null.
Could you please help with the above problem.
I am trying to access the linked item and perform a transition on it.
Regards
Solved by gasevsm. Go to Solution.
Hi Raj,
I am trying to reproduce your scenario but it seems to be working fine for me. Here is my Linking PL with Search definition:
And when I access it with the following script I get the correct title for the item:
var linked = item.PL_W_SEARCH;
println(linked.TITLE);
Can you try to see what is different about your setup?
Hello Hagay,
Thanks for the response.
I am able to access the linked item via a script.
The issue I am facing is that when I debug a script and provide the needed details for an item.
I am able to view the item contents, however linked items from a pickerlist are always null.
I am not sure what is it that I am doing incorrectly.
Regards
Rohan
