Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Linking Picklist access in a script
3 REPLIES 3
Rohan.Raj
465 Views, 3 Replies
Hello Team,
Good day.
I have a workspace there is a field which is linking picklist item with search filter from another workspace.
I am able to filter the item in edit mode and save it.
However  in an action script, when I try to access the linked item I always get null.
Could you please help with the above problem.
I am trying to access the linked item and perform a transition on it.
Regards
3 REPLIES 3
dvirh
in reply to: Rohan.Raj
Hi Raj,
I am trying to reproduce your scenario but it seems to be working fine for me. Here is my Linking PL with Search definition:
And when I access it with the following script I get the correct title for the item:
var linked = item.PL_W_SEARCH;
println(linked.TITLE);
Can you try to see what is different about your setup?
Hagay Dvir
Engineering Manager
Fusion Manage
Rohan.Raj
Hello Hagay,
Thanks for the response.
I am able to access the linked item via a script.
The issue I am facing is that when I debug a script and provide the needed details for an item.
I am able to view the item contents, however linked items from a pickerlist are always null.
I am not sure what is it that I am doing incorrectly.
Regards
Rohan
gasevsm
This is a debugger bug. Will be fixed with a future release.
mg
Martin Gasevski | Fusion 360 Team Product Manager
