Hi, I'm putting together an Advanced Print View for our change order worspace and I want to include as much information about the items linked to the record as I can. In particular I want to include the From and To revision fields on the Linked Item tab. These fields are absent when using Insert Artifact. How can I access these fields for an Advanced Print View?
Thanks.
Ah,,,
Interesting question, Joe what options / manipulation of the ${} artifact have you tried so far (hint,hint)...
Hi Joe,
Sorry I lead you down the wrong path,,
Let me explain:
Basic Rule of thumb for Advance Print View: if you can read hit it by JavaScript, you can Use it in HTML in Advanced Print View (this is not a constant though!)
So at this time the only elements in linkedItems that are avalible to you are:
1. Number of the Item
2. Name of the Item
3. Custom fields
Also circling around to what i was hinting at:
(Not a constant but is 90% acceptions are here also)
Much like in JavaScript where an item element is item.SOMETHING or item.tab.SOMETHING
HTML (APV) is the same but it goes with
Name of the Field = ${workspace.metadata.TABNAME.fields.NAMEOFFIELD.title}
Vaule of the Field = ${workspace.metadata.TABNAME.fields.NAMEOFFIED.value}
Hope this helps some!
Also final thought:
That would be an awesome Idea to add to the IdeaStation to have this Scriptable by HTML and JavaScipt, and Included in the LinkedItems widget in the AVP....
Joe,
Yes you got it!
APV is limited by JavaScript (for the most part)
How would you access the lifecycle transition in the AVP?
I tried ${linkedItem.lifecycle.value} and that did not work.
The ${linkedItem.lifecycle} is a String representing the lifecycle transition name. It is not related to the FROM/TO .
Unfortunately Fusion Lifecycle does not have any script method or Advanced Print View capabilities at the moment to expose the "FROM" and "To".
I encourage you to post that request on the Idea Station.
We are new to Fusion Lifecycle and I am now starting the process of creating Advanced Print Views for our ECNs. I amazed to discover you can not add Revision From: and To: to the view. This seems like a basic piece of information to be included in a PDF'ed copy of the record.
I will be suggesting this in the Idea station, but, I will be scratching my head as to why it is not there already.
Bob Wing
Lytron Inc.
