What coding should I learn to be able to create codes for computed fields? What language should I learn to be able to create scripts (Administration --> System Configuration --> Scripting)?
Solved by gasevsm. Go to Solution.
Greetings,
Comupted Fields use PostgreSQL syntax:
http://www.postgresql.org/docs/9.3/static/functions.html
http://www.postgresql.org/docs/9.3/static/datatype.html
Scripts are written in JavaScript 1.5 notitation.
https://developer.mozilla.org/en-US/docs/Web/JavaScript
http://www.w3schools.com/js/default.asp
For more info on PLM360 Scripting, please see this Help section. http://help.autodesk.com/view/PLM/ENU/?guid=GUID-1EFE1FAC-1CFF-4F2E-987F-9801DF590E57
Hope this helps,
