After this last update, I noticed in Document Change Order workspace, on the affected items tab, the Item column view of the linked item is extra wide. I used to be able to see the item, the Lifecycle, Revision, etc. on my screen, but now I have to either scroll to the right or click on the arrow to remove the filter view columns in order to see what I need. This is very inconvenient as it creates an extra step each time I need to look at an item.
What is the reason for this column having such a wide view?
I thought the changes and updates your developers made were supposed to make working in Autodesk easier. Each time you make "upgrades" I find you create extra work for me.
Can you provide a screenshot of the Affected Items tab so I can see what you are describing?
Charmene,
I'm going to move this to a case and escalate it to the PLM 360 Development team as the field does look to large.
