I can get it to show No by default because the picklist orders alphabetically and you can then choose 'Show First value by default' but unless I create a new Picklist and number the options 1_Yes and 2_No or similar, I can't see an easy way of showing the last value (in this case) by default. Adding the numbers doesn't make for very easy reading for the user.
Any other ideas?
Fiona
Solved by BiggePLM. Go to Solution.
Fiona,
You should be able to set the default Value in the field set up. (See the attached screen shot)
If you want to have the sort order of the picklist set, I know of no way to do that currently in PLM, except by the method you describe (Picklist sort order is Alphabetic, So numbers first, ABC second.
Hope this answers your question
Bob Donovan
