Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
How to get item owner name and assign the name to another field for that record?
3 REPLIES 3
jdow
704 Views, 3 Replies
I have the following script to get the owner of a record to then put that owner name into a picklist field...the owner name i'm retrieving will match a name in the picklist.  I can get the owner name but can't assign it to the APPROVALS_REQUIRED field (the picklist).  Is this possible?
var oName=item.master.owner; // Get the owner name of the record
//var arName=item.APPROVALS_REQUIRED; //Get the approved_required field user name
var nameArray=oName.displayName.split(" "); // Split the name of user into an array by firstname / lastname
var fName=nameArray[0]; // First name
var lName=nameArray[1]; // Last name
var userINFO = Security.searchUsers({lastName:lName, firstName:fName}); //Find the user
item.APPROVALS_REQUIRED=Security.loadUser(userINFO[0].id);  //Changes approvals_required to owner name.
item.APPROVALS_REQUIRED=(lName+","+fName);
John
JD
3 REPLIES 3
jared.sund
in reply to: jdow
John,
I think there's a much simpler way to do this.  The following should work, assuming that APPROVALS_REQUIRED is a multi-select pick list.
Try this:
item.APPROVALS_REQUIRED.add(item.master.owner.lastName + ", " + item.master.owner.firstName);
Jared Sund
Sr. Product Line Manager, Product Lifecycle Management
Autodesk, Inc.
jdow
in reply to: jared.sund
Awesome...much easier...works great...thank you.
How would this change it this is a single select picklist?
Is there a remove username option from a multi-select pick list?
John
JD
gasevsm
in reply to: jdow
Hi, it would be something like: item.SINGLE_APPROVAL_REQUIRED = item.master.owner.lastName + ", " + item.master.owner.firstName;
Also check if your picklist displays users as 'last, first' or 'first last' and adjust your script accordingly.
Martin Gasevski
Martin Gasevski | Fusion 360 Team Product Manager
