PLM 360 General Discussion
dkeeley
Message 1 of 3 (101 Views)
Grid Print Order
101 Views, 2 Replies
02-21-2013 01:57 AM
I have specified in the 'grid tab' in a workspace setup that the sort order should be by a particular column. That seems to work fine when viewing the grid in the UI. However, when I print the grid (using a printview) it reverts back to being sorted by the row ID. Is there any way to change this?
David.
I have discussed this with my direct support contact. I have created a solution using scripts.
David.
Product Support
mazerab
Message 2 of 3 (79 Views)
Re: Grid Print Order
02-21-2013 03:20 PM in reply to: dkeeley
Hi David,
This is not something I can reproduce. Could you please provide us with an example? In my test, the column I sorted on contained characters only, no numbers. Could the issue be browser dependent?
Bastien Mazeran
Support Specialist
Product Support
dkeeley
Message 3 of 3 (75 Views)
02-22-2013 12:43 AM in reply to: dkeeley
David.
