PLM 360 General Discussion
Member
0 Kudos
Post 1 of 5
Getting the Author of Item
160 Views, 4 Replies
04-20-2012 08:56 AM
Is it possible to return the creater (owner) of an item to use in that items fileds. For example if you wanted each item created in a workspace to contain the Auhor of that item. Seems like I should be able to do that as a computed field, but have failed to figure it out. Also looked at a script and did not get anywhere. Your guidance is appreciated, seems like there has to be a way to do this.
Product Support
48 Kudos
Post 2 of 5
Re: Getting the Author of Item
04-20-2012 09:21 AM in reply to: rcoffey2
Rodney,
Finding the creator of an item within the workspace can be obtained one of two ways. The first way being the usage of the Change log, which is a built in tab, that anyone with the right permissions could see.
However, if I understand your question correctly you will want to use a behavior script that will use the argument of “ownerID” that will pull the information that you are looking for and place it with in a designated field within the item.
Reference: http://wikihelp.autodesk.com/PLM_360/enu/Help/Help/0032-Administ32/0064-Scriptin64/0071-Scriptin71
Look under Objects on item Properties -> Descriptor (read- only)
Joe Piggee
Support Specialist
Product Support
Member
0 Kudos
Post 3 of 5
04-20-2012 12:01 PM in reply to: rcoffey2
These were the options I was looking at. The change log is great, but like to have it as a filed in the details. I was looking at it as an action scipt on item creation, but am having a little trouble generating the script from whats in that wiki. Is there any change you could provide a sample. Seems like this would be an awefully usefull library script. One that just fills in data based on values in the system. I know there is the one to pass properties with item creation sciprt, but all I am looking to do is fill this out, not create a new item.
So
If Author is null then populate Author with Created by or Onwer, I think either of these will wotk. If you could provide a sample for the code it would be greatly appreciated, I will add it to my library and use it for some other things I have been looking at.
Board Manager
27 Kudos
Post 4 of 5
04-22-2012 07:15 AM in reply to: rcoffey2
I've done this in the past really only for one reason that makes sense - when you want to add the "owner" into a field that can be used in the descriptor.  I used this on the "tasks" workspace in the past when I had a ton of tasks on Projects - makes the Gantt easier to read on an overview level.
Here is the code I used. (action script)
var usrName = "";
//Get the user's full name - "First Last"
var usr = Security.loadUser(userID);
usrName = usr.lastName + ", " + usr.firstName;
//check to see if the user names match, otherwise update it.
//Note - the "RESPONSIBLE" field in this script is a pick list to the
//"user, all" pick list.  This will ensure no typo's
if (usrName !== item.RESPONSIBLE){
//the conditional checks to make sure that it only write if the value
//has changed, otherwise skip it - good practices to avoid a messy
//change log.
item.OWNER = usrName;
Normall I'm not a fan of this type of workflow because you're essentially duplicating data.  However, it does the job and I have used it.
Keep in mind that to get this to work you have to fire the script.  I do it on the behavior for "modify".
Brian Roepke
Director of PLM & PDM
Board Manager
27 Kudos
Post 5 of 5
04-23-2012 07:00 AM in reply to: broepke
Small error above - Change in the last line
to
item.RESPONSIBLE= usrName;
Brian Roepke
