Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Get workspaceID of item
6 REPLIES 6
654 Views, 6 Replies
I am writing a script that is supposed to check if I have a relationship from a particular workspace.
How do I do that?
I have:
for (var i in item.relationships) {
 >>>    item.relationships[i].item  <<<
6 REPLIES 6
depending on what you want to do you can use
if (item.relationships.length === 0){ do something //this would do somehting if the relationship array is empty i.e. there is no relationship
or
if (item.relationships.length > 0){ do something else //this would do somehting if the relationship array is not empty i.e. there are relationships
Hope this helps
Ian
I understand, but that is not all I want to do. I want to go though each element in the relationship array to see if one of them belongs to a particular workspace.
I assume the only way I can to that is to compare it to a static workspaceID.
But I don't know how to get the workspaceID from an item (or DMSID).
Sten
gasevsm
This isn't possible presently. It will become available in the coming release. The syntax will be someItem.master.workspaceID as well as someItem.master.dmsID.
MG
Martin Gasevski | Fusion 360 Team Product Manager
in reply to: gasevsm
Hi Martin,
Is it possible yet to get the workspaceID of an item via scripting? I have tested item.decriptor.workspaceID but it comes back as null.
David.
Hi Martin,
Ignore that. I just checked item.master.workspaceID and that works.
David.
gasevsm
Glad you found it easily. Yes please use item.master.* to access it's properties as defined in the online AKN help. Be mindful that system doesn't handle system ids reservation yet. So a newly spawned item via script would have undefined workspaceID and dmsID as they aren't yet allocated - the item is still virtual; it commits to a tangible item in DB right after script's successful completion and is when it's IDs get assigned. Hope this helps,
Martin Gasevski | Product Manager | Autodesk PLM 360
