Is it normal for fields of type Float to show a change to precision in the Change Log every time the item is updated, regardless of whether that field is changed or not?
For example, field "Target Profit Margin" is of type Float with precision 2.
The change log shows the following, with an entry for each time I edit Item Details then save, but without changing anything.
Date Time:11/20/2013 8:22:48 AM
Action: Edit Item
Description: Target Profit Margin: 1.380000000000 ⇒ 1.38
Date Time:11/20/2013 8:22:36 AM
Action: Edit Item
Date Time:11/20/2013 8:12:21 AM
Action: Edit Item
This is happening for all of the float fields in the workspace on the Item Details tab (that's the extent of my testing so far).
Thanks.
Solved by jpiggee. Go to Solution.
Yes, this is normal behavior for a float field, yes.
The reason why has to do with how a SQL database (postgreSQL in our case) teats a float field.
SQL logic dictates a float field to be rounded to the precision of stated quantity then truncated and placed into the field as integer value, so every time the system thinks it is being edited it will always need to do this, regardless of whether it has been modified or not.
So, basically what you are seeing is the OCD of the SQL world in action, the field wasn’t changed but It must round up and truncate, then value and place it back into the field.
