Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Filter On Computational Fields
4 REPLIES 4
Colgan
641 Views, 4 Replies
Hi Guys,
I'm pretty sure the answer is no but sure I'll ask anyway, can you filter on a computational field? I'm using 'DATEDIFF' to get the number of days between two dates. I'd like to set up a view and filter on the computed result(negative days). So a filter on the field as 'Starts with' a '-'.
Cheers
Saoirse
4 REPLIES 4
Andrew.Shaw
in reply to: Colgan
Hello Saoirse,
This is possible. The way I did it was to ensure that the result was a number and then I added a filter displaying values "less than" 0.
Filter setting
Best regards,
Andrew Shaw
Premium Support Specialist PLM/PDM
Global Services
Autodesk, Inc.
MMcCabe
in reply to: Andrew.Shaw
Hi Andrew,
Thanks so much for the quick response. I need to change my syntax to cast the date difference as an integer so. I'm getting an error with the syntax below:
CAST(DATEDIFF('DAY', CONFIRMED_DELIVERY_DATE, SHIPPED_DATE)AS INTEGER)
Can you identify where I'm going wrong?
Cheers
Saoirse
Andrew.Shaw
in reply to: MMcCabe
Hello Saoirse,
Here's an example that manages both negative and positive results:
(CASE WHEN DATE3 > DATE1 THEN 1 ELSE -1 END) * to_number(to_char((DATE1 - DATE3),'dd'),'99')
Best regards,
Andrew Shaw
Global Services
Autodesk, Inc.
Colgan
That's fantastic Andrew. I have my integers now.
Thanks so much for your assistance.
Saoirse
