Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Derived Image Field
4 REPLIES 4
CodeMonkey831
601 Views, 4 Replies
Derived Image Field
Are derived fields not intended to work with images, or is there a known bug?  I've added a derived field is meant to pull an image field from another workspace.  The image will preview when editing the item, but after saving, the image does not show.
Editing the item:
After saving the item:
Tags (1)
4 REPLIES 4
jpiggee
in reply to: CodeMonkey831
Hi Jason,
Thanks for the info, but as you mentioned, yes derived fields are only supporting text based input at this time. However this might be expanded in the future.
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
n.kathel
Please can you advise if PLM360 can now use derived images?
dvirh
in reply to: n.kathel
We did not envision derived fields to work with images, but they do work under certain conditions and we do hope to add official support for deriving images in the future.
Hagay Dvir
Engineering Manager
Fusion Manage
Autodesk, Inc.
As Hagay said there are some work arounds, you can do this by adding a derived picklist to the workspace that contains the images
Step 1
Create a workspace to be your image library
Step 2
Create 2 fields in your workspaces that needs to pull in the image
Image Name = Pick list that links to the workspace that was created in Step 1
Image jpg = Derived field pivoting on the Image name pick lists, and showing the Image jpg
Step 3
Select a name from the  pick list and this will be automatically display the image below
Mike Watkins
PLM Product Manager
Twitter: @mikewatkinsweb
Blog: http://mikewatkinsweb.blogspot.com
Autodesk Ltd, One Discovery Place, Columbus Drive
Farnborough, Hampshire, GU14 0NZ
