PLM 360 General Discussion
Distinguished Contributor
obourne
Message 1 of 3 (99 Views)
Customizing UI - Item Details
99 Views, 2 Replies
11-15-2012 11:02 AM
Is there a way to customize the layout of the Item Details tab? Currently I see the fields stacked top to bottom. I want to be able to arrange the field display as a form and input data that way. This would be a parallel to enetring in data on a PDF document.
The attached file shows a document I cutrrently use. I'd like to migrate this to 360 but keep the current layout.
Product Support
JohnCHill
Message 2 of 3 (95 Views)
Re: Customizing UI - Item Details
11-15-2012 11:40 AM in reply to: obourne
When you are building the Item Details Fields for your workspace try using a Matrix.  With the Matrix you can move fields from left to right on the Item Details tab and I have created multiple workspaces based on a PDF document.
Hope this helps,
John
John Hill
Support Specialist
Product Support
obourne
Message 3 of 3 (78 Views)
11-15-2012 04:00 PM in reply to: JohnCHill
I checked it out. It's OK. I would prefer full on customization but can probably make it work as is.
Thanks for the tip. :smileyhappy:
