Hi There,
I am working on a workspace right now with computed fields to calculate float field values. When I attempt to save my work I recieve an error telling me that "There has been a problem processing my request". I ensured that the formula was entered properly and double checked my other fields but I am stumped. I am working in a Development Tennant and would greatly appreciate if someone could take a look at what I am trying to do.
Stephen
Solved by gasevsm. Go to Solution.
Good Mornign Martin,
Both the scr and computed fields are a float type.
Here is one example from the workspace:
Quoted EAU: 120000
Total Savings Per Quote @ 100%: 1.65 (standard float field)
Customer Cost Savings Per Quote: 1.30 (standard float field)
Company Savings: 0.30 (computed float field (TOTAL_SAVINGS_PER_QUOTE_@_100%-CUSTOMER_COST_SAVINGS))
Forecasted Annual Customer Savings (computed float field (QUOTED_EAU*CUSTOMER_COST_SAVINGS_PER_QUOTE))
Forecasted Annual Company Savings (computed float field (QUOTED_EAU*COMPANY_SAVINGS))
No additional behavior scripts.
I am recieving the error when I edit an existing float field to add the computed formula. I was able to clone a field and add the computed formula but when I went to save the layout I recieved the error as well.
Stephen
Martin,
I'm still struggling with this.
I removed the '@' and '%' symbol, so the field is now "TOTAL SAVINGS PER QUOTE AT 100 PERCENT". I did notice that the field ID is limited on characters. So the field ID for this field name is actually "TOTAL SAVINGS PER QUOTE" -without the "AT 100 PERCENT"
I tried the new formula "TOTAL_SAVINGS_PER_QUOTE-CUSTOMER_COST_SAVINGS_PER_QUOTE"
I also tried "TOTAL_SAVINGS_PER_QUOTE - CUSTOMER_COST_SAVINGS_PER_QUOTE"
and "TOTAL_SAVINGS_PER_QUOTE -CUSTOMER_COST_SAVINGS_PER_QUOTE"
Stephen
Hi Stephen,
Regardless of what the field name is, you must use the exact field ID as it appears in the admin 'Editing Field' modal dialog - see image below. Copy and Paste that field ID into your computed formula. Nevertheless, if your field ID is defined as 'TOTAL_SAVINGS_PER_QUOTE', then this is exactly what you need to define in the computer field.
>> So the field ID for this field name is actually "TOTAL SAVINGS PER QUOTE".
Each field ID is unique, must not start with a digit, must not have whitespaces (consequtive whitespaces are replaced by single underscore) and is of limited character length. The quoted field ID is incorrect as its missing underscores. I would expect to see "TOTAL_SAVINGS_PER_QUOTE" at the very least.
- Could you share your computed field formula please?
- Also edit each field and share image of how they are defined.
- One more note, the computed field can only pull values for fields that reside in the same workspace as the computed field. I hope that you are not referencing field IDs defined in a different workspace.
Martin,
This one is resolved.
My first issue was my QUOTED_EAU field was not a float field. I was trying to use a Single Line Text field in my computed formula that was in a float field.
My second issue was I was trying to make one computed field push data to another computed field within the same workspace. - Is there another formual I can use to make a computed field communicate to another computed field?
Stephen
