Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
COMPUTED FIELD (CASE STATEMENT)
2 REPLIES 2
dkeeley
640 Views, 2 Replies
I am having problem with creating CASE statements in calculated fields. I am getting continuous server error messages.
David.
2 REPLIES 2
jpiggee
in reply to: dkeeley
Hi David,
I moved this to a new topic for better visibility.
Can you please describe what you are trying to do with a CASE statement, as well as the type of Fields you are using so that we may better help you.
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
nguyentru
Hi David,
We understand the issue, and we are in the process of fixing this bug.  It should be release soon.
In the mean time you will need to inser Else statement into your case statement have the computed field work.
For Example:
CASE
WHEN(TYPE=4) and (RATE is not null)
WHEN(TYPE=1) and (COST is not NULL)
ELSE 0
END
THANKS,
Trung
Trung Nguyen | PLM Product Management | Autodesk, Inc.
