PLM 360 General Discussion
68 Kudos
Post 1 of 16
Change Milestone State using scripting
373 Views, 15 Replies
01-05-2013 05:29 AM
I want to be able to change the workflow state referenced by a milestone via scripting. The WikiHelp seems to suggest this is possible but I have not been able to get it to work. My script is as follows;
item.milestones[0].setWorkflowState('[99] Cancelled');
The Wikihelp states the following;
Methods on the Milestones Array
milestones.setWorkflowState("SHORT_NAME")
Method to set the workflow state associated with the milestone (milestones.workflowState). The "SHORT_NAME" parameter takes the value for the milestones.workflowState.shortName property.
Can you please let me know what I'm doing wrong?
David.
Hi Joe,
Thanks for the reply.
I just want tp be crystal clear about this incase I've misunderstood something;
A milestone has the following properties;
1 Workflow State
2 Milestone event
3 Target Date
4 Status
5 Warning Days before
6 Workflow progress
So if I understand you correctly the following statements are correct??
a> Properties 1 to 6 can be set on creation via a script.
b> Properties 2 to 6 can be edited via a script. Property 1 cannot.
c> A milestone cannot be deleted via scripting.
68 Kudos
Post 2 of 16
Re: Change Milestone State using scripting
01-05-2013 02:07 PM in reply to: dkeeley
Also,
is it possible to change a milstone date after it has been created using scripting?
David.
Product Support
49 Kudos
Post 3 of 16
01-07-2013 07:07 AM in reply to: dkeeley
David,
Workflow states dictate milestones, not the other way around. You can have a workflow state create or adjust a milestone, or look at a milestone for a condition of validation, but you cannot have a milestone adjust a workflow state.
Also yes you can adjust a milestone date via scripting after the milestone is created, if you know the name of the milestone your trying to affect.
Joe Piggee
Support Specialist
Product Support
68 Kudos
Post 4 of 16
01-07-2013 07:29 AM in reply to: piggeej
Hi Joe,
Thanks for the reply. So if I understand you correctly it is not possible to change the workflow state asscoiated to an existing milestone via scripting?
David.
Product Support
49 Kudos
Post 5 of 16
01-07-2013 07:38 AM in reply to: dkeeley
David,
There isn’t a way for a script to start based on when a milestone changes. Scripts only work on workflow changes or item creation / change.
Joe Piggee
Support Specialist
Product Support
68 Kudos
Post 6 of 16
01-07-2013 07:41 AM in reply to: piggeej
Joe,
I think we have our wires crossed. The script is executed by a workspace behaviour (edit). All I want to do is change the workflow state referenced by the milestone at that point.
Does that clear things up?
David.
Product Support
49 Kudos
Post 7 of 16
01-07-2013 08:06 AM in reply to: dkeeley
David,
If you are trying to change the workflow step based on a milestone. Then you are looking at an ‘if’ or 'case' statement and using:
                item.performWorkflowTransition(transID, 'comments')
Joe Piggee
Support Specialist
Product Support
68 Kudos
Post 8 of 16
01-07-2013 08:32 AM in reply to: dkeeley
Hi Joe,
I think we still have our wires crossed ;-)
I'll PM you to discuss further.
David.
68 Kudos
Post 9 of 16
01-07-2013 12:49 PM in reply to: dkeeley
Hi Joe,
I have tried to illustrate what I am trying to do on the attached document. Please let me know if this sheds any light.
David.
Product Support
49 Kudos
Post 10 of 16
01-08-2013 06:28 AM in reply to: dkeeley
David,
Based on what your showing all you can do at that point is set the “Closed” milestone to completed at 100% and create a new milestone for “Cancel”.
You cannot change one milestone for another or delete and replace the milestone by scripting.
Joe Piggee
Support Specialist
Product Support
