Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Change Milestone State using scripting
15 REPLIES 15
Message 1 of 16
1226 Views, 15 Replies
I want to be able to change the workflow state referenced by a milestone via scripting. The WikiHelp seems to suggest this is possible but I have not been able to get it to work. My script is as follows;
item.milestones[0].setWorkflowState('[99] Cancelled');
The Wikihelp states the following;
Methods on the Milestones Array
milestones.setWorkflowState("SHORT_NAME")
Method to set the workflow state associated with the milestone (milestones.workflowState). The "SHORT_NAME" parameter takes the value for the milestones.workflowState.shortName property.
Can you please let me know what I'm doing wrong?
David.
15 REPLIES 15
Message 2 of 16
Also,
is it possible to change a milstone date after it has been created using scripting?
David.
Message 3 of 16
jpiggee
David,
Workflow states dictate milestones, not the other way around. You can have a workflow state create or adjust a milestone, or look at a milestone for a condition of validation, but you cannot have a milestone adjust a workflow state.
Also yes you can adjust a milestone date via scripting after the milestone is created, if you know the name of the milestone your trying to affect.
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
Message 4 of 16
in reply to: jpiggee
Hi Joe,
Thanks for the reply. So if I understand you correctly it is not possible to change the workflow state asscoiated to an existing milestone via scripting?
David.
Message 5 of 16
jpiggee
David,
There isn’t a way for a script to start based on when a milestone changes. Scripts only work on workflow changes or item creation / change.
Joseph Piggee
TPI Composites
Message 6 of 16
Joe,
I think we have our wires crossed. The script is executed by a workspace behaviour (edit). All I want to do is change the workflow state referenced by the milestone at that point.
Does that clear things up?
David.
Message 7 of 16
jpiggee
David,
If you are trying to change the workflow step based on a milestone. Then you are looking at an ‘if’ or 'case' statement and using:
                item.performWorkflowTransition(transID, 'comments')
Joseph Piggee
TPI Composites
Message 8 of 16
Hi Joe,
I think we still have our wires crossed 😉
I'll PM you to discuss further.
David.
Message 9 of 16
Hi Joe,
I have tried to illustrate what I am trying to do on the attached document. Please let me know if this sheds any light.
David.
Message 10 of 16
jpiggee
David,
Based on what your showing all you can do at that point is set the “Closed” milestone to completed at 100% and create a new milestone for “Cancel”.
You cannot change one milestone for another or delete and replace the milestone by scripting.
Joseph Piggee
TPI Composites
Message 11 of 16
Joe,
Thanks for the feedback. I'm still a little confused. The WikiHelp suggests that this functionality should be available. The following is stated in the scripting reference page (link below). Have I misunderstood?
Is this only available at milestone creation? If so then this clears things up.
Message 12 of 16
jpiggee
David,
This is available for creation or modification. Not for deletion or renaming.
Joseph Piggee
TPI Composites
Message 13 of 16
Hi Joe,
I just want tp be crystal clear about this incase I've misunderstood something;
A milestone has the following properties;
1 Workflow State
2 Milestone event
3 Target Date
4 Status
5 Warning Days before
6 Workflow progress
So if I understand you correctly the following statements are correct??
a> Properties 1 to 6 can be set on creation via a script.
b> Properties 2 to 6 can be edited via a script. Property 1 cannot.
c> A milestone cannot be deleted via scripting.
Message 14 of 16
jpiggee
David,
Correct!
Joseph Piggee
TPI Composites
Message 15 of 16
Thanks for the help Joe (and your patience Smiley Happy).
Great service.
Message 16 of 16
jpiggee
Glad I could help out Smiley Happy
Joseph Piggee
TPI Composites
