I have a revision controlled item and BOMs workspace (From the standard tenant). In the workspace I use the standard "Sourcing" tab, in which I can save suppliers and quote information. Up until recently I was able to set one of the quotes to default (so it's used in the BOM). Now I cannot change the default option, regardless if there is a default one already or not. I'm the only admin and I havn't changed the settings at all, is there an update recently which changed anything around the suppliers tab?
Best regards,
Johan Kenneberg
Solved by dvirh. Go to Solution.
I'm using Firefox v28.0 and my college who noticed the problem is on IE 11.0. I've also tried Chrome v 34.0.1847.131.
I tested the "Incognito Mode" in my Chrome version and the problem persists.
Best regards,
Johan Kenneberg
I went ahead and created the support case (09563501) - someone will reach out to you soon!
Michelle
Johan,
When you say you can't change the default, is it because there is not button to change the default quote? That might be because you are looking at the Released Revision of the item. You can only change the default quote in the Sourcing tab of the Working Revision of the item. This is a known limitation of the system and we expect to fix it in an upcoming release.
Hi Hagay,
I cannot change it regardless of release status. I've tested both unreleased, working and released revision. These tests were performed in Firefox 29.0.
Best regards,
Johan Kenneberg
Johan,
The issue I was referring to has been resolved with the May release that went over the weekend. Can you please test it again and let me know if this is resolved or not for your use case?
Thanks!
Johan,
BTW, I see that the two images you attached are showing Edit mode for the Sourcing tab. The 'Set Default' action is only available in the main screen for the Sourcing tab and not in the Edit screen. This may be contraintuitive, but this is how it's always been. See attached image.
