Is there a way to control the column width in a BOM (when viewed in browser).
When I view my BOM the description' field is the same width as 'Quantity' even though my description fields are all 50+ characters and quantity is only a number.
Why is the BOM viewer not better at determining the column fields.
If this is not possible I have plenty of ideas to how to improve this.
1) Autoscale based on text
2) Add option for min/max field width in bom setup window
3) Add scaling factor to bom setup windows where I tell it that 'description' must be 10x wider than 'quantity' (like a gui grid manager)
4) Double click on column divider will autoscale (like most modern gui's)
Solved by nguyentru. Go to Solution.
Hi Sten,
Currently in the BOM Tab - the columns are adjustable, allowing the user to shift to right or left for a better fit of display.
You can move the descriptor field to the right to show more characters. You can also move the Units and Quantity to the left to cut down on wasted space.
I use Chrome Browser, this allow the saving of my settings. Once I set the column width to my desire needs, it will save the format through the records.
I also see you posted a lot of ideas to help improve the BOM View.
Please post your wonderful ideas and enhancement requests on the Idea Station.
thank you,
Trung
