Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Batch update after the items are imported?
8 REPLIES 8
Message 1 of 9
629 Views, 8 Replies
I wonder if there is a way to do data batch update for a [WS]? Something similair to a SQL statement:
UPDATE [WS]Product
SET mktgrp = 'Lateral Systems'
WHERE mktgrp = 'LAT';
Thanks!
Frank
Tags (1)
8 REPLIES 8
Message 2 of 9
michelle.stone
You can use the import tool to make mass updates - just make sure you match on fields so it knows to update records.  Help here in the Wiki - scroll down to the "Update and Insert New Records" section.
Michelle
Michelle Stone
Technical Marketing, PDM & PLM
Message 3 of 9
Once I use the 'mktgrp' column as "Match On" column, I cannot use it as a column to do the data update. In another word, I cannot use import/update approach to do selected update on one column?
Frank
Message 4 of 9
jpiggee
Frank,
In order to do an update to a batch of pre-existing records in a workspace, you need to make sure to choose a unique value to do the match on. This unique value has to exist in every record, but be unique unto the record.
Unfortunately if this is not an available option, the next best option would be to update the spreadsheet, purge the workspace and re-import all records.
Joseph Piggee
Fusion 360 Administrator
TPI Composites
jpiggee@tpicomposites.com
Tags (1)
Message 5 of 9
michelle.stone
Do you have an autonumber field you can match on instead?  I did a quick check and created a 'Product' ws w/mktgroup field.  Only created a handful of records, but it shows the idea.
Ran a report only grabbing the 'LAT' entries that I could use for the import:
Then created the import and matched on my autonumber (read this tip about using them - very useful!):
End result:
Hope that helps.
Michelle Stone
Message 6 of 9
Thanks Joe and Michelle! Now I understand  what PLM 360's import/update approach means.
My original SQL statement is essentially a selected update, which means search/update on centain records.matching some criteria on the column to be updated.
Does server-side sciprting allows passing a SQL statement to the back-end database?
Frank
Message 7 of 9
jpiggee
Frank,
SQL scripting is only allowed to work with the current item you are in, in the current workspace you are working with.
Java scripting is the sever side scripting that allows you to use and change information not only in the current item and workspace, but across the entire tenant.
A good way to think about it is SQL is cosmetic scripting or “math / display” scripting, whereas Java is the “workhorse.”
Joseph Piggee
TPI Composites
Message 8 of 9
Hi Joe,
Thanks for the tip! I'm an old school now.
Is the server side scripting available for end users to do this kind of selected batch update using Java scripting?
If so, how can this be done?
Frank
Message 9 of 9
jpiggee
Frank,
Unfortunately no, the best ways to do a mass update would be the methods Michelle and I posted earlier, sorry.
Joseph Piggee
TPI Composites
