Fusion Manage Forum
Welcome to Autodesk’s Fusion Manage (formerly Fusion 360 Manage) Forum. Share your knowledge, ask questions, and explore popular Fusion Manage topics.
Automatically Advance Workflow Based On Item Details
2 REPLIES 2
530 Views, 2 Replies
Hi, I'm at another loss here.  Is it possible to have a workflow advance (transition performed) without user interaction?  Here's the setup:
  • Two checkbox fields on the Item Details tab: Task A and Task B
  • Item is in state 03a
  • When both checkboxes are checked item is automatically transitioned from state 03a to 03b without requiring anyone to do a Workflow Action
Can this be done and what's the basic methodology to do so?
Thank you!
2 REPLIES 2
bastien.mazeran
You could consider adding a new OnEdit script that will check to see if the checkbox is selected, and if it is perform the workflow transition to next state.
The method to use is item.performWorkflowTransition().
I hope this helps.
Bastien Mazeran
Technical Support Specialist
in reply to: bastien.mazeran
Perfect, that's what I needed. I missed this method in the Scripting Reference but now I see it.
Thank you!
