Hi, I'm at another loss here. Is it possible to have a workflow advance (transition performed) without user interaction? Here's the setup:
Can this be done and what's the basic methodology to do so?
Thank you!
Solved by bastien.mazeran. Go to Solution.
You could consider adding a new OnEdit script that will check to see if the checkbox is selected, and if it is perform the workflow transition to next state.
The method to use is item.performWorkflowTransition().
I hope this helps.
