PLM 360 General Discussion
Valued Contributor
j.hendrickson
Message 1 of 3 (167 Views)
Automatically Advance Workflow Based On Item Details
167 Views, 2 Replies
11-20-2013 05:28 PM
Hi, I'm at another loss here.  Is it possible to have a workflow advance (transition performed) without user interaction?  Here's the setup:
  • Two checkbox fields on the Item Details tab: Task A and Task B
  • Item is in state 03a
  • When both checkboxes are checked item is automatically transitioned from state 03a to 03b without requiring anyone to do a Workflow Action
Can this be done and what's the basic methodology to do so?
Thank you!
You could consider adding a new OnEdit script that will check to see if the checkbox is selected, and if it is perform the workflow transition to next state.
The method to use is item.performWorkflowTransition().
I hope this helps.
Product Support
mazerab
Message 2 of 3 (141 Views)
Re: Automatically Advance Workflow Based On Item Details
11-22-2013 03:26 PM in reply to: j.hendrickson
I hope this helps.
Bastien Mazeran
Support Specialist
Product Support
Valued Contributor
j.hendrickson
Message 3 of 3 (139 Views)
11-22-2013 04:49 PM in reply to: mazerab
Perfect, that's what I needed. I missed this method in the Scripting Reference but now I see it.
Thank you!
