When I attach a file in my PLM360 tenant, I can’t see the preview.
In my personal profile the setting Show Thumbnail for attachment is enabled.
The strange thing is that I can see and navigate the thumbnails of documents already attached in my PLM360 site (they were samples prepared by Autodesk), but not the ones attached by myself.
I am using an Administrator user.
Thanks in advance
Fausto
Hi Fausto,
It seems that the issue is related to the way PDF Creator generates the files (possibly the compatibility level).
I will send your file to the development team so when can check whether it's related to the iFilter used on the server.
Thank you very much for your help.
Best regards,
Hello Fausto,
Thank you very much for the investigation and the feedback.
Best regards,
