PLM 360 General Discussion
scottmoyse
Message 1 of 3 (108 Views)
Are Scripts affected by current user permissions?
108 Views, 2 Replies
10-11-2012 02:36 PM
In other words, if the currently logged in user doesn't have permissions to see items being referenced in other workspaces by a script, or uses fields in hidden sections. Will the scripts still run as intended?
Cheers
Scott Moyse
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Cheers!
Scott - I double checked with our scripting guru to verify.
"the script will run..  script permissions are only goverened by the access to the events.  Meaning, if you have access to edit, add item, or perform workflow transitions, these will fire scripts and they will run as you expect."
Hope that helps!
Michelle
Product Support
michelle.stone
Message 2 of 3 (105 Views)
Re: Are Scripts affected by current user permissions?
10-11-2012 04:04 PM in reply to: scottmoyse
Hope that helps!
Michelle
Michelle Stone
PLM Product Manager
scottmoyse
Message 3 of 3 (102 Views)
10-11-2012 04:10 PM in reply to: michelle.stone
perfect thank you
Cheers
Scott Moyse
